So I have been wondering, what is the difference between these two motors? I notice visually that the older 3800 has the intake angled toward the driver side, but what are the differences between the two 3800's? Which one is better?
1995-1997 vs 1998-2002 3800's
Re: 1995-1997 vs 1998-2002 3800's
Their both the same engine, no changes but the upper intake and TB.Last edited by ssms5411; 08-09-2013, 04:07 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Engines are basically identical for 95-98 (slanted UIM w/ cable TB) and 99-02 (straight UIM w/ eTB). There are minor changes to wiring and sensors each year so they are not always "plug and play". Internals are the same.
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by nwilson44 View Postso there are no power or torque differences?
Raven
Later model 3800s have better cylinder head casting as well. I think it is around 99 that they'd changed some things with the casting/machining process around the valve guides. Some of the performance companies won't use the earlier heads as cores as they're prone to cracking around the valve guides.
2000+ have tubular manifolds, which is worth a nominal gain in performance and also less blood/cursing/time spent changing the spark plugs.
