Re: 3.8 camaro?
Bad transmission mount and probably worn out motor mount/broken bolts.
Down on power could be a variety of issues. Most likely needs list of service (plugs, wires, fuel filter, oil change). Also could be the catalytic converter. If you can, take the car to a local shop (autozone/oreillys) and get the codes/code history read.
Squeaks are probably bushings that are going out or a bad shock.
Dents and collisions will drop the value. $2500 because it has body damage and needs to be run through mechanically as it sounds like it hasn't been maintained.
Originally posted by countryguy1717
View Post
View Post
View Post
