It's that time. I had my car in the shop to chase down some electrical gremlins and they let me know that I'm losing oil and coolant from my intake manifold gasket. My repair manual is not with me right now, but I'm curious, how tough is this job? Any common pitfalls , or things to look out for? I've got a fairly well equipped garage.
Upper intake Gasket
Re: Upper intake Gasket
Originally posted by Docta View PostIt's your upper? weird.. typically the lower leaks.
This was the recommended part on their invoice estimate:
http://www.amazon.com/Fel-Pro-MS9580.../dp/B000C2EDMC
The little clips that hold the cowl together will tear you up. Its best to clip them off with dykes to save some pain. The job is relatively easy, the worst part is the metal bracket on the passenger side head. The bolts on the plenum are 3/8 not 10mm.Team NoVa
Originally posted by Atrum Rosa View PostThis was the recommended part on their invoice estimate:
And watch out for the two bolts inside the lower intake. There's one on the left front of it, and one in the right rear {facing the engine} and they're buried down inside next to the ports.
http://www.amazon.com/Fel-Pro-MS9574...+plenum+gasket
That would be an upper intake gasket, more commonly referred to as the plenum gasket.
Here's all the parts that I think are needed on such a job (upper/lower intake gaskets):
Lower gasket kit
http://www.rockauto.com/catalog/more...339&cc=1371248
Heater hose "elbows"
http://www.rockauto.com/catalog/more...103&cc=1371248
And then I found this Dorman kit for the upper intake manifold, think it'll fit our car? It fits everything else that uses the 3800 series 2.
http://www.rockauto.com/catalog/moreinfo.php?pk=370875
Otherwise, it would be this gasket kit for the upper intake manifold
http://www.rockauto.com/catalog/moreinfo.php?pk=2194744Last edited by enzia35; 09-15-2013, 10:24 AM.
Originally posted by enzia35 View PostHere's all the parts that I think are needed on such a job (upper/lower intake gaskets):
Lower gasket kit
The "upper intake" is referred to as a plenum gasket on most sites for our cars.
So then, this one huh?
http://www.rockauto.com/catalog/more...724&cc=1371248
It says throttle body gasket not included, is that something else I should get?
http://www.rockauto.com/catalog/more...415&cc=1371248
Why are they so different (the upper intake)?Last edited by enzia35; 09-15-2013, 11:24 AM.
