injector fitment - FirebirdV6.com/CamaroV6.com Message Board
injector fitment
  • injector fitment
    Hey guys I am haveing an injector go bad so I was going to swap it out with another so I pulled 3 out of a grand prix 3.8 series two, I was just wanting to make sure they would work.
    And man I seen three l67 still fully there at my local pull a part
    Re: injector fitment
    Depends on the year of your vehicle if their Bosch style or Muti-tec.
      You have 3 stock ones in your car? If so, no... those are a different flow rate.
      Otherwise, if the connectors match up they should work in a matched set. I'd be wary of pulling injectors from different cars though.
        idk if there boch all i know is the numbers on the side of the injector, but they do have 4 holes on the tip where it sprays out.Yeah i would be wary to but im going to try to clean them very good like this video.
        http://www.youtube.com/watch?v=7aT4S1lIBAY
          i typed in the number off the side and they look the same http://www.autozone.com/autozone/acc...er=891173_0_0_
            Cleaning doesn't flow match them. And do you have a set of 6 of the same ones?
              What year vehicle is yours and what did year and car did you pull them out of?
                Docta I am sorry I thought you were talking about how clean they would be, I have 3 but I could probably get the rest
                Ssms I have a 98 and I didn't thing to look at the year of the other car when I got them
                  which cars could i get injectors off of that would work for my camaro, its a 98 with cat back and high-flow filter is all.
                  i have been trying to chase a miss fire down for about a year now,it has got worse and before with fuel additives it would stop but now nothing does the trick except time and sooner or later it will just stop .i have changed the plug,wire,coil and just messed with the injector in the car to see if it was stuck and it was clicking open and closed like it should so idk what to do next.
                    With chasing the missfire, how have you been doing it? Do you have a code indicating which cylinder(s) are missfiring? If so, have you tried moving coils and/or injectors to other cylinders to see if the missfire follows the part?
                      i have been starting simple and working from there and it started with cylinder 3 miss fire only at idle and wasn't noticeable then went to small spurts of bad miss firing where it made the car sound like a motorcycle and now it does it for days and vibrates enough when miss firing to see it in the rear view mirror when idling and on a cold crank it now puffs what looks like white smoke or grayish,last time i had the codes ran which i think what set them off was from one cylinder miss firing it said random miss fire,cat bad, and maybe an 02 code i cant remember.
                      i have changed the coil 2,plug 2,wire 2.
                      and just tested to see if injector still clicking and it was. ran gas additives but the fix was only momentary.
