Security Light - Forever ON - FirebirdV6.com/CamaroV6.com Message Board
  • Security Light - Forever ON
    For awhile last year, the VATS would not let me fire up the engine and I would be turning the ignition key tumbler all the way to START and you hear nothing at all except the normal chime. Happened sporadically.
    This year proves different. The Security Light is always on and I can start ( fire up ) the motor right up with no problem. Around June the VATS does a 180 and allows me a free pass for now lol.
    So my questions are: What is going on and is this a fluke?
    Is the tumbler defective? I'm not sure what else to look for but it seems great for now I can turn my ignition on without worry while the Security light is permanently on.
    Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
    Replace the key cylinder man. There are 2 white wires that read the resistance of your key to see if its the right key to pass security. One is most likely broken off.
    I had the same problem but did not pay attention to it. Untill I thought it would not let me turn my car on. Replaced it and the light went away.
    The part cost around 50 bucks and you could rent the tools to do it for around 50 bucks also. Just follow the stearing colum removal write up on here some where around here
    Sent from my SGH-T999 using Tapatalk 2
      Re: Security Light - Forever ON
      Good info, i have the key cylinder on order now. Next would be a puller of some sort as you explained. Any particular links would be useful as I am out of state and the Camaro is at an airport. Thanks!
        You will need a steering wheel puller, t-27 or t-30 bit socket. Small t-??(I don't know the size for this one) screw driver. Lock spring compressor I belive its called and Philips screw driver, flat head. I think that's about it oh and a 21 mm socket.
