I disconnected the negative pole from the battery to erase the EGR code, when reconnected after 20 minutes the temp gauge was just dead, the needle or arm was not on zero, but all way down, and the SES light is still on. What do I do?
Temp gauge dead
Re: Temp gauge dead
Yeah man mine does the exact same thing every once in a while, I have no clue. I even replaced the temp sensor. It only does it once in a blue moon. I would start changing the sensor and cleaning the connections, and see where that takes you.
Re: Temp gauge dead
Did you run the car to where it would be at a normal temp? If the gauge does not move then either the sensor is dead, the wire is disconnected, or the actual gauge is dead.
As for the EGR, as soon as the PCM commands the EGR to move and does not see a response it likes, the code will be set. So this may happen immediately. I don't know if the PCM waits for the engine to warm up before operating the EGR.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: Temp gauge dead
Forgot to mention, you can try grounding the sensor lead and see if the gauge moves all the way to the hot position.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: Temp gauge dead
Originally posted by Rob Bell View PostDid you run the car to where it would be at a normal temp? If the gauge does not move then either the sensor is dead, the wire is disconnected, or the actual gauge is dead.
As for the EGR, as soon as the PCM commands the EGR to move and does not see a response it likes, the code will be set. So this may happen immediately. I don't know if the PCM waits for the engine to warm up before operating the EGR.Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
Re: Temp gauge dead
Hey guys, I ran the car this morning and after 15 minutes the temp gauge fix itself, but not the EGR code. I need ask Orelly's guys or pepboys to clear the code, hopefully they want to do it.Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
Re: Temp gauge dead
Originally posted by borispeed View PostHey guys, I ran the car this morning and after 15 minutes the temp gauge fix itself, but not the EGR code. I need ask Orelly's guys or pepboys to clear the code, hopefully they want to do it.
Re: Temp gauge dead
Yes, ask them to let you see the code reader, and then hit the clear code button.
How long has your SES light been on for the EGR? Mine used to do that and it would go away after a couple of days. What happened with mine, and this is a known problem with GM vehicles, is that the PCM expects to see the EGR valve move faster than the valve is sometimes capable of. Example would be, the PCM commands that the valve move 5 clicks in a certain timeframe, and the valve is not fast enough, so it moved 4 clicks in that timeframe. Maybe it really moved the whole 5 clicks, but it just didn't do it in the alotted time. So the PCM sees that it's inaccurate, and sets a code. You could end up spending hundreds of dollars on new EGRs and never solve this problem. The only fix is to "de-sensitize" the PCM via tuning.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: Temp gauge dead
Originally posted by nwilson44 View PostThey aren't allowed to but ask them if they will let you do it if they refuse. If you can get the car tuned just delete it. Mine was causing more harm than anything. I found two used tubes that wouldnt stop leaking. If the manifold is leaking let me know because I have an extra driver side manifold with the EGR connection.Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
Re: Temp gauge dead
Originally posted by Rob Bell View PostYes, ask them to let you see the code reader, and then hit the clear code button.
How long has your SES light been on for the EGR? Mine used to do that and it would go away after a couple of days. What happened with mine, and this is a known problem with GM vehicles, is that the PCM expects to see the EGR valve move faster than the valve is sometimes capable of. Example would be, the PCM commands that the valve move 5 clicks in a certain timeframe, and the valve is not fast enough, so it moved 4 clicks in that timeframe. Maybe it really moved the whole 5 clicks, but it just didn't do it in the alotted time. So the PCM sees that it's inaccurate, and sets a code. You could end up spending hundreds of dollars on new EGRs and never solve this problem. The only fix is to "de-sensitize" the PCM via tuning.Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
