Hey guys, I am hearing a lot of noise from my ignition system that I recently replaced. Any advice of something I can check for? I hear it arcing all the time! new coils, plugs, and wires. I am not sure if the Accel coils require dielectric grease underneath them or not but any advice is welcome, I just want the noise gone!
Ignition Noises
Re: Ignition Noises
Are you getting any DTC codes? How do you know its arcing can you see it at night?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Ignition Noises
Originally posted by ssms5411 View PostAre you getting any DTC codes? How do you know its arcing can you see it at night?
Re: Ignition Noises
Next time let it warm up and use a listening device just to be sure it is coming from there and or from which coil. I have a feeling that might not be your problem.
The reason why I think that's not the problem is because if it's arching your engine would be stumbling during idling.Last edited by 2.8 Bird; 01-30-2014, 04:13 AM.
Re: Ignition Noises
Do you still have your stock coils? Try swapping them in and see if the problem continues. There's mixed reviews on all aftermarket 3800 coils. And for what it's worth, ZZP posted a picture a while ago on their Facebook of OEM, MSD, Accel, and ZZP coils cut in half, and the OEM's looked the best.aka FreedStyle
Chaddrich Freed
(1 of 443) 2002 SLP Firebird GT #107 (244rwhp/254rwtq naturally aspirated)
2008 Silverado Crew Cab 5.3L 4x4
Re: Ignition Noises
Originally posted by 2.8 Bird View PostNext time let it warm up and use a listening device just to be sure it is coming from there and or from which coil. I have a feeling that might not be your problem.
Re: Ignition Noises
Originally posted by CFreed11 View PostDo you still have your stock coils? Try swapping them in and see if the problem continues. There's mixed reviews on all aftermarket 3800 coils. And for what it's worth, ZZP posted a picture a while ago on their Facebook of OEM, MSD, Accel, and ZZP coils cut in half, and the OEM's looked the best.
Re: Ignition Noises
It may also be worth mentioning that in the past week, its gone threw a coil and it burned up 2 wires. (not from the headers but the resistance in the wires shot up all of the sudden making them not work)
Re: Ignition Noises
I would think if it was the ICM or coils you would be getting codes like PO300 or a specfic cylinder code.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Ignition Noises
Originally posted by ssms5411 View PostI would think if it was the ICM or coils you would be getting codes like PO300 or a specfic cylinder code.
Re: Ignition Noises
See if you can dig up an ICM from a local junkyard. I'm sure they can't be more than a few dollars used. Maybe someone else knows if other 3800 ICM's fit our cars or if they are F-Body specific. Or just spring for a new one. As with any other part, they can be defective from the factory though. I replaced the ICM in my old Grand Am with an Autozone part and the first one was defective, the second still worked until the next owner ran the car into the ground.aka FreedStyle
Chaddrich Freed
Re: Ignition Noises
Icms from 96 through 09 work, either supercharged or n\a I just put a 2006 grand prix icm in mine(paid $35). Same for the coils 96 through 09 supercharged or N\a.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Ignition Noises
Originally posted by nwilson44 View PostYeah I am not getting any ignition codes. I am just getting broken coils and wires. These were all new too. Ive been threw 3-4 sets of coils. 2 sets of wires.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
