Help figuring out which gasket?
Re: Help figuring out which gasket?
I can't really see the lower part of the lower intake but your thermo gasket housing is discolored and it might be leaking there.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Plenum gasket does have coolant go through it. Goes up through to the TB and back down.
Just get both the upper and lower intake manifold gaskets and be done with it. You'll want the metal problem solver gaskets for the bottom and use a good bit of silicone on the corners where it meets the intake valley.
Originally posted by Ed2011 View PostI started fingering under the thermo housing and a little piece of the gasket itself fell off....
How hard is it to replace LIM and UIM?? Is there a write up flowing around?Last edited by ssms5411; 02-22-2014, 07:09 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by WarShrike View PostPlenum gasket does have coolant go through it. Goes up through to the TB and back down.
Originally posted by Docta View PostOh yeah huh... that's why you get O-rings in a gasket set. Dur. Been too long since I've messed with mine, I guess.aka FreedStyle
Chaddrich Freed
(1 of 443) 2002 SLP Firebird GT #107 (244rwhp/254rwtq naturally aspirated)
2008 Silverado Crew Cab 5.3L 4x4
Originally posted by CFreed11 View PostNot having to mess with it too often can be a good thing ;) Just means that it's all working properly and not leaking. That, or your engine is overdue for a few mods... :burn:
The necessity of replacing upper and lower intake manifold gaskets is very, very common on this engine. I would make sure that at the same time you flush the radiator completely. there is an updated set of gaskets that are superior to the OEM gaskets. I had this work done a month ago. Ignored, this will help you throw a rod and they you are dead meat.Phil
When you replace the thermo gasket, I would see if that fixes your problem. No reason to replace good gaskets. But if you do , the ones I posted earlier will do. ZZperfomance should have the alm. coolant elbow, will have 2 elbows ,you'll just use the one. They will have the alm. LIM gaskets. Any of the auto part stores should have the UIM gasket and RTV for the LIM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
sorry to say but my car did the exact same thing and it was the LIM, if your problem is the same as mine sooner or later the whole front of the LIM gaskets will give out and will dump coolant out at least that's what mine did.But go with the zzp LIM gaskets because i did the parts store ones and i just tore apart my engine this week and the two year old parts store LIM gaskets were already breaking apart.
The attachment storage directory does not exist or is not writable.3 hours ago -
by 2.8 BirdSo there going to be anything new or update to the site since Bill is now the owner?
I know there's still alot of interest in the fbody V6....3 days ago -
by FirebirdGTAll - sorry but there seems to be some glitches from moving to a new Host - hopefully they will be fixed soon.
If needed you can email me...2 weeks ago
