I would look at the ECT sensor, its the only one that would cause it not to read. Its on the front of the lower intake underneath the TB.
Also check the wiring. Where did it sit for 3 months? Can rodents get to it? They are notorious for eating the wiring.
Hopefully it is something simple.
Sounds like everything is working properly. Is the sensor grounded to the intake properly? To check use a jumper cable from the sensor body to the engine block. Did you clean the threads on the intake? Also if you used Teflon tape on the threads you could insulate the ground of the sensor.
