My son has an 02 Camaro V6 and he goes to school 200 miles away so I'm not at the car at the moment. He called this afternoon and said the heater is not putting out any warm air. Blower works but the air is cold. He said it had been running for 15 minutes and the temp gauge showed a steady 205-210. Then he calls back 20 minutes later and said he kept letting it warm up and the temp gauge almost pegged out at 260 so he turned it off. The car has a history of a slow coolant leak and he said when he first realized it wasn't warming up as fast as it usually does he added coolant. Sounds like he put about 3/4 of a gallon in it to fill it up.
I had him make sure the serpentine belt was on. Then I told him to let it cool down for several hours. Make sure the coolant was at proper level then start it and drive around the block to see if it starts to work. I said to bring it back to the dorm if the temp rises above 210 again and in that case we'll have to have it towed somewhere to be looked at.
The temp there was about 10 degrees today. My thought is a stuck thermostat? Where is that at on a V6? Can you smack the housing with a wrench like on a 327?
Any thoughts / suggestions?
