How many wires are coming from you guy's pigtail on your alternator? My car has one coming out put the ac delco replacement has 4! Is it supposed to have 4?
Alternator
Re: Alternator
On my 96' it has a 3-4 pin connector but only 1 wire coming out and its the wire that tells my gauge what volts its at. I would use a voltmeter to see if its putting out any volts.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Alternator
Its a 3 pin connector going into the ALT. and has only 1 wire coming out of the connector, I think its the middle where the wire is coming out.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Alternator
Steve, would you mind getting a volt reading at that pin on the harness side of that connector with the key on? I've got a 96' camaro also but different engine PCM, and I'm curious if it is affecting my dash voltmeter.
Re: Alternator
Originally posted by techsan23 View PostSteve, would you mind getting a volt reading at that pin on the harness side of that connector with the key on? I've got a 96' camaro also but different engine PCM, and I'm curious if it is affecting my dash voltmeter.
Yeah no problem, are you running a 97' pcm? I get it in a little bit.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Alternator
Correction its a 4 pin connector with 1 wire coming out, Techsan23 I got 0 volts with the key on.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Alternator
Originally posted by ssms5411 View PostYeah no problem, are you running a 97' pcm? I get it in a little bit.
Re: Alternator
Thats weird its having volts with the car off, sounds like it has power from the battery at all times. I would get a Haynes manual if you don't already have one and look at the wiring diagrams and see if you can rewire it for your gauge cluster.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
The attachment storage directory does not exist or is not writable.2 hours ago -
by 2.8 BirdSo there going to be anything new or update to the site since Bill is now the owner?
I know there's still alot of interest in the fbody V6....3 days ago -
by FirebirdGTAll - sorry but there seems to be some glitches from moving to a new Host - hopefully they will be fixed soon.
If needed you can email me...2 weeks ago
