Blend Door - FirebirdV6.com/CamaroV6.com Message Board
Blend Door
  • Blend Door
    Has anyone replaced the blend door? I have 97 Firebird that was checked out and I was told it's probably the blend door. Thanks.
    Re: Blend Door
    Whats a blend door?
      Re: Blend Door
      the blend door allows the air to switch form cold to hot, when you turn the cold/hot knob on the dash, theres also blend doors for the vents/floor/defrost
        Re: Blend Door
        Thanks didn't know that.
          Re: Blend Door
          ive heard of them, never talked to someone who actually had to replace them though.
          Follow me!
          Or this
            Re: Blend Door
            My A/C checks out fine but just doesn't cool. That's why I'm going to replace blend door.
              Re: Blend Door
              After having my car for 18 years , I think thats the only thing on my car I haven't had to mess with is the A/C controls. Good luck with it.
                Re: Blend Door
                probably helps you never have to switch the ac off in zona, lol
                Follow me!
                Or this
                  Re: Blend Door
                  You *Should* hear the blend door actuator "clunk" when going from heat to ac. If you don't hear the clunk then your actuator might have gone out. I'm not exactly sure where it's located though. :twak:
                  96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
                    Re: Blend Door
                    Thats def. true,LOL I haven't had my heater on in about 5 or more years, now its bypassed for the coolant lines for the turbo.
                      Re: Blend Door
                      lucky bastard lol. there have been times this winter where i was wishing someone would set me on fire just to stay warm haha.
                      Follow me!
                      Or this
                        Re: Blend Door
                        Old post but I got the a/c working but I need a new blend door. Anyone know where to get one? Thanks.
                          Re: Blend Door
                          Are you talking about the blend door actuator?
                          Don't really have a whole lot of knowledge on that. Perhaps O'Reilly.
                            Re: Blend Door
                            did U try ebay?
                              Re: Blend Door
                              Actuator is fine. The blend door is not sealing off allowing hot air from the heater core to mix in with the a/c. The air from the evaporator is ice cold but coming out the vents it's just cool.
                              No luck on Ebay.
                                Still trying to find oil leak
                                3 days ago
                                Getting some work done on my truck
