Okay guys so my car is having low voltage and its getting on my nerves lol. I just want to fix it! So whats happening is that I'll start it up when its cold and it'll run normal voltage closer to the last white line on the gauge. As the car gets warm the voltage drops and stays at or below 13V no matter how loud I crank up the radio, A/C or whatever! The car has a new Optima battery, and AC delco Alternator. I also just replaced the pigtail on my alternator harness. Any help would be appreciated!
13V while driving?
Re: 13V while driving?
Originally posted by FIREBIRDV6RAGE View PostHave you checked with the actual volts at the batery with a volt meter? It could be that your gauge on the cluster is just going out or a conection to it is messed up some how, not conected right or a wire on it is striped.
Sent from my SGH-T999 using Tapatalk
Sounds about right for stock, I have a 200 amp ALt. and my volts are in the 13's, I'll double check today when I drive it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Also did the big 3 wire upgrade. Which is bigger 4ga. wire from battery to ALt., big 1ga. ground wire to block, and big 4ga. wire from battery to accessory box.Last edited by ssms5411; 03-31-2014, 12:39 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Ls1 is wired differently, also I wouldn't trust the stock gauges they can be deceiving, I would only trust mechanical gauges or scan gauges. On mine it was 12.9 to 13.1 on the scan gauge.Last edited by ssms5411; 03-31-2014, 02:48 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
The 13.0 at idle and when driving with the A/C on it was 12.1 and 12.5 with no voltage boosters. I took my Caspers voltage booster off. My stock gauge never moved.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostThe 13.0 at idle and when driving with the A/C on it was 12.1 and 12.5 with no voltage boosters. I took my Caspers voltage booster off. My stock gauge never moved.
With car running my stock volt gauge in the dash reads around the high side of 15 volts {Too high imho}but my ohmmeter set to volts on battery reads 14.2 volts. Right about where you would want it while running. Turn the car off and they both read in the 12.4 range. Don't trust the factory gauge too much I think the guy who designed it may have also been involved in the design of the water heater quick disconnects.
wow this is good info for me!..i always wondered about this voltage problem...and i never understood it...except my gauge needle stays in the orange when the car is warm...and when its cold its way above normal..and the upgrades i have is..2 optima yellow tops..220 amp alt. big 3 upgrade with 0/0 gauge wire and a 24 farad capacitor..with my power probe hooked up to my alt i always get around 13.5-14v.....which doesnt seem good enough for me..btw i have a '94 3.4 camaro...steve what voltage do u get with caspers voltage booster on?...im glad im not the only one with this problem
Originally posted by darkflare999 View Postwow this is good info for me!..i always wondered about this voltage problem...and i never understood it...except my gauge needle stays in the orange when the car is warm...and when its cold its way above normal..and the upgrades i have is..2 optima yellow tops..220 amp alt. big 3 upgrade with 0/0 gauge wire and a 24 farad capacitor..with my power probe hooked up to my alt i always get around 13.5-14v.....which doesnt seem good enough for me..btw i have a '94 3.4 camaro...steve what voltage do u get with caspers voltage booster on?...im glad im not the only one with this problemLast edited by ssms5411; 04-01-2014, 08:09 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by nwilson44 View PostOkay guys so my car is having low voltage and its getting on my nerves lol. I just want to fix it! So whats happening is that I'll start it up when its cold and it'll run normal voltage closer to the last white line on the gauge. As the car gets warm the voltage drops and stays at or below 13V no matter how loud I crank up the radio, A/C or whatever! The car has a new Optima battery, and AC delco Alternator. I also just replaced the pigtail on my alternator harness. Any help would be appreciated!
The stock gauge is a joke. You need to connect a real VOM to see what is actually going on.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...2 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...4 days ago
