2000 Chevrolet Camaro:
3.8 V6
A4
96 K miles
Engine bolts-on: December
• Air silencer delete
• High flow air filter (K&N)
• Lid (SLP)
• Ram air (Fast Toys)
Exhaust:
• Catback
• Headers with Y-pipe (Pacestter)
Drivetrain:
• 3:42 gears (Factory)
• One piece steel drive shaft (Factory)
• Posi-differential (Factory)
Suspension:
• New 17 in wheels and tires
• Shocks (Koni Str)
• Front bushings (Moog: Tie rods, Control arm upper and lower, ball joint upper and lower)
• 35/22mm hollow sway bars
• Tubular lower control arms (Founders performance)
• Tubular pan-hard (Founders performance)
• Fast-steering ratio
Brakes:
• Brake pads (Akebono Performance Ultra Premium Ceramic Pad)
• Brake fluid
• Rotors (Duralast)
Cooling system:
• Aluminum elbows (Advance Auto parts)
• Coolant flush (Dexcool)
• Radiator (Made in China)
• Thermostat (180°, Duralast)
• Upper and lower radiator hoses (AC Delco)
• Water pump (Duralast)
Ignition:
• Battery (Ever Start Maxx)
• Sparkplugs (NKG)
• Sparkplugs wires (Bosch)
Emissions:
• Oxygen sensor and extension (Denso)
Exterior:
• Berger panel with an Ls1 emblem (about +100 more hp)
• Halo headlights
• Red painted calipers
• SS Hood
• SS spoiler
• Turn signals lights
Interior:
• 30th anniversary seats and door panels
• Dash pad
• Sound system (Radio, 4 speakers, amplifier and subwoofer
Other:
• Belt (Goodyear Gatorback Poly V)
• Power Steering pressure hose (AC Delco)
• Upper and lower intake manifold aluminum gaskets (Fel-Pro)
I might be forgetting something.
Next break (December) modifications: Sub-frames or TA cover, bump stops, spark plug wire heat protectors and fuel filter.
Maybe next I’ll add a camshaft.
3.8 V6
A4
96 K miles
• Lid (SLP)
Exhaust:
• Catback
Drivetrain:
Suspension:
• Shocks (Koni Str)
Brakes:
• Brake fluid
• Rotors (Duralast)
Cooling system:
Ignition:
• Sparkplugs (NKG)
Emissions:
Exterior:
• Halo headlights
• SS Hood
• SS spoiler
Interior:
• Dash pad
Other:
