side gapping spark plugs - FirebirdV6.com/CamaroV6.com Message Board
  • side gapping spark plugs
    apparently a racing secret since the 60's...first I have heard of it.
    Let's here a discussion.
    Here is some background info for anyone else like me who hasn't heard about this before:
    Just like indexing a spark plug (concept wise) you chop the top portion of the plug off so that you get a bigger spark that is exposed directly to the mixture.
    http://performanceunlimited.com/docu...degapping.html
    Discuss!! :drool:
    Re: side gapping spark plugs
    I know if you have force induction that's not a good idea to do. NA perhaps, but then again you still have to balance this with proper fuel mixture. Or else, detonation.
      I actually read a few things that said it is great for FI as it reduces the chance of having blow out?
        I would imagine that it would change the way the flame kernel acts within the combustion chamber. Keep in mind that when engineers design cylinder heads they are most likely working under the assumption of a standard un-modified plug. So it may actually cause degradation to the efficiency of how the A/F burns.
        Just thoughts off the top of my head.
        Daily: '02 Black Yukon Denali
        Toy: '06 Torrid Red GTO
        Gone: '07 Charcoal Yamaha R6
        Gone: Ex-wife, lol
          Explain? or keep thinking out loud lol
          the stronger the spark generally the more power you can make no? That's why guys love Individual coil packs > our coil packs > rotor/cap
          Isn't that also the philosphophy for why guys buy MSD ignition setups and bigger wires etc?
            Having different coils or wires wouldn't change the kernel, only make the spark stronger. I'm trying to find some pictures/theory on the spark plug shape thing I'm tossing around. I could be completely off track with this though. LOL
            Gone: Ex-wife, lol
              Check this out.
              http://www.tvu.com/PCycleByCycleweb.html
              I think this may help you understand what I'm getting at.
              Look for a picture labeled #13.
              Gone: Ex-wife, lol
                That's hotter spark but you want to be in the cold range with FI. This is indeed a popular mode with hot rodders but they were running with lead base fuel and very high octane. Not a good idea if you run with regular fuel. Also I heard someone mention that this type side gapping is used mainly for drag racing and not for everyday normal driving. Those people who race with this often replaced them after each race.
                Here's a good site of how side gapping is done.
                http://www.instructables.com/id/Save.../?comments=all
                  Interesting points...is this not still used while racing though? where guys arent using lead anymore?
                  Check this out.
                  I'm having a tough time understanding whats going on here? I might need to read the whole article when I have some time.
                    Guess you haven't seen MotoGP or F1 plugs. This is some neat stuff, called a surface gap or surface discharge spark plug. Such close tolerances between the piston and combustion chamber + valves leaves little to no room for the electrode to stick out.
                    In order: F1, GP Bike, Ford Focus
                      I have a set of autolite plugs that I modified awhile back. I used them in my turbo 3500 engine and did notice a difference in performance but pulled the plugs in favor of a set of ngk non-projected plugs. My theory was the less of the spark plug tang hanging out the less chance it would have to heat up and cause detonation.
                      • Manimal
                        Coil springs
                        by Manimal
                      • Manimal
                        Newby here
                        by Manimal
