LIM Gasket - FirebirdV6.com/CamaroV6.com Message Board
LIM Gasket
  • LIM Gasket
    Time to replace again.
    Original factory GM gasket lasted 204,000 miles, second dealer installed gasket (can only assume it was GM part) lasted 56,000 miles.
    Suggestions for brand to get this time?
    Raven
    Re: LIM Gasket
    I would go with the alm. Intake gaskets from zzp and just use felpro for the lower. Also I can't remember does the tensioner need to come off when you do the lower? If it does do the alm. coolant elbow too.
      Re: LIM Gasket
      This should eliminate the plastic failure.
      http://shop.zzperformance.com/store/...ke-Gasket.aspx
      For the upper I would just go with the normal felpro part.
      I would also agree with the aluminum elbows as well.
      http://shop.zzperformance.com/store/...nt-Elbows.aspx
      Daily: '02 Black Yukon Denali
      Toy: '06 Torrid Red GTO
      Gone: Powerdyned '02 Pewter Camaro
      Gone: '07 Charcoal Yamaha R6
      Gone: Ex-wife, lol
        Re: LIM Gasket
        I've got the Felpro version of the alum LIM gasket and happy with it, MS98014T. I do have pitting on the LIM surfaces, so on install i used a razor blade and skimmed black rtv over the pits to fill them in.
        2001 Pewter Firebird Y87, M5
        Go Sabres!
          Re: LIM Gasket
          Well that's NOT where the leak is after all.
          It's the heater hose! Time for V6FixIt.com
          Raven
            Re: LIM Gasket
            Thats good news. On those heater hoses put some sealant around the top of them and let them dry, it will hold them in place alot better. I think I used some gray intake gasket sealer. When I installed them without it I had one blow out when I floored it one day and lost alot of coolant I think it had to be the pressure side that popped off.
              Re: LIM Gasket
              Did you install factory, or V6FixIt.com hose kit?
              Raven
                Re: LIM Gasket
                V6 fixit kit.
                  Re: LIM Gasket
                  V6 fixit kit.
                  Thanks for the tip.
                  Raven
                    Still trying to find oil leak
                    3 days ago
                    Getting some work done on my truck
