I would go with the alm. Intake gaskets from zzp and just use felpro for the lower. Also I can't remember does the tensioner need to come off when you do the lower? If it does do the alm. coolant elbow too.
I've got the Felpro version of the alum LIM gasket and happy with it, MS98014T. I do have pitting on the LIM surfaces, so on install i used a razor blade and skimmed black rtv over the pits to fill them in.
2001 Pewter Firebird Y87, M5
Thats good news. On those heater hoses put some sealant around the top of them and let them dry, it will hold them in place alot better. I think I used some gray intake gasket sealer. When I installed them without it I had one blow out when I floored it one day and lost alot of coolant I think it had to be the pressure side that popped off.
Did you install factory, or V6FixIt.com hose kit?
