Full A/C removal - FirebirdV6.com/CamaroV6.com Message Board
Full A/C removal
  • Full A/C removal
    Hi,
    I have probably spend 8+ hours searching for a detailed way to fully remove the a/c from my 4th gen Camaro. I removed the compressor, and all lines years ago but the box on the firewall (i believe it is the condenser) needs to go. I have not found any pics, or tutorials on how to remove this - and I have been having one hell of a time figuring it out myself. Has anyone done this removal? And most of all could this be done without loosing heat as well? I would like to clean up the engine bay, but I do not want to loose heating. Thanks in advance.
    Still trying to find oil leak
    3 days ago
    Getting some work done on my truck
