sloppy steering - FirebirdV6.com/CamaroV6.com Message Board
sloppy steering
  • sloppy steering
    I have several inches of play in my steering. I have new outer tie rods, old inner ones. Any Ideas? Car is a 2002 v6 camaro.
    thanks!
    Re: sloppy steering
    Probably the steering column and steering box need to be inspected to see if anything is loose.
      Re: sloppy steering
      Look at the bushings all around too.
      Just jack it up with the front wheels free and have someone turn the wheels and see what it does.
      I did this once to my old '88 pick up and I ended up replacing worn out bushes.
        Still trying to find oil leak
        3 days ago
        Getting some work done on my truck
