I am hearing bad things about airbags and now that my car is 16 years old, I am concerned that the airbag may be one of the recalled bags and if I had an accident it would be a killer. I have a Swiss made Wood steering wheel that I had on an 1985 MR2 and I have a few adapters but wonder if it would fit the Camaro and if adapters are available.
Removing steering wheel....how?
Re: Removing steering wheel....how?
I used a Momo adapter on mine with a Sparco steering wheel. Not hard at all but you'll need a steering wheel puller.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
You'll probably need a new adapter, one that's made for 93-02 Fbody. The horn is working well but I have to hold the lever for the drivers side turn signal for it to light up. Passenger side or right side works fine , I think if I break it in more it will work better.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I don't know would have to look it up.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by PalmHarbor View PostI am hearing bad things about airbags and now that my car is 16 years old, I am concerned that the airbag may be one of the recalled bags and if I had an accident it would be a killer. I have a Swiss made Wood steering wheel that I had on an 1985 MR2 and I have a few adapters but wonder if it would fit the Camaro and if adapters are available.
I removed my wheel years ago for the same reason - also they reduced the "explosive" after 1996 as it was determined to be too powerful.
See if you can find a Pontiac 4-SPOKE LEATHER STEERING WHEEL Trans Am 88-91. This is going on in time - replacing the aftermarket Luisi Steering Wheel.
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
