Thoughts on Prestone Triple Protection - FirebirdV6.com/CamaroV6.com Message Board
  • Thoughts on Prestone Triple Protection
    It's suppose to condition your gasket and seal any damage to it (permanently).
    Any thoughts on this product before I use it?
    Re: Thoughts on Prestone Triple Protection
    Does this go into the coolant or oil, never heard of it but Preston makes decent stuff.
      It goes into the coolant. It has beads that you put in and once you putin the chemical the beads breakdown and attaches itself to anything that's crack or broken. Suppose to be safe for water pump and radiator. I want to use it on the grand prix.
        I don't know about that stuff, I used some stuff for my head gaskets and it is all beaded up on the bottom of the radiator. It worked like a champ but it gets pretty messy. I would just fix the leaks and be done. I would just use it for short term projects until you can fix it right.
          So, if something goes unexpectedly wrong...Prestone pays? No? Thought so.
