okay.. i have 29,000 miles on my car. where do you guys recommend to get at!! I hear jiffy lube does a good job. Yet, I want to use royal blue I hear they do well with nitrous applications.
where do you guys flush your car
Oil, ya just do it yourself since you are going to have to buy your own oil anyway. I believe you mean Royal Purple, btw.
And for Radiator, I'm a supporter of ditching dex-cool for the green stuff (After a really good flush)\'96 A4 Camaro 3800<br />Nothing but... <br />Flowmaster 40 series
It takes a little while to totally flush it out of your engine, but trust me...It's Worth It!sigpic
i agree with everyone about doing it yourself, but i dont agree about changing from dex-cool. read my other response to this i posted the other day in this forum
^^^ distilled water ... not tap water plz ...Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
I've not seen much used oil analysis of Royal Purple's "regular" oils that makes me want to spend that much more than Mobil 1. What's the point doing that anyway if the Jiffy Lube people are going to screw on a rebadged, cheap Fram oil filter anyway.
I agree all of this stuff is DIY, including dropping the pan and the filter from the trans. [I know some of you prefer flushing, but come on, this car only has 29K on the clock...] I use the Dexcool still, and have had no problems. Honestly, most people have problems with this stuff because they don't do preventative maintenace on their cooling system at all.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
BTW, if you can't/don't want to climb under your car to do the trans and differential, the LAST place I would take it is a quick oil change shop.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
