I've been talking to some people who have had this problem with 3.8's but I can't ever remember hearing one about a Camaro. Something about a plastic intake that corrodes. Our intake manifolds are not plastic are they? Do they have a leak problem?
Do the 3.8's have the problem with Intake manifolds leaking?
uh lower intake gasket looks like it is plastic, yes. I just replaced mine, hopefully it will seal.
Do they corrode? I dont know2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
I was thinking of doing the EGR reroute to remove carbon deposit from intake, and to lower intake temps (possibly saving intake gaskets??)?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
The gaskets are plastic, i just replaced mine the other week because they were leaking coolant. I think my problem was that the bolts started getting loose, but i had to remove every thing anyways to tighten them. So i just replaced them anyways. I too im fixing to do the egr delete. My intakes, and injectors were a mess because to this this thing.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Yes, the GM 3.8 is notorious for springing an upper intake maifold gasket leak allowing coolant to leak on the front of the engine. Other GM cars with the 3.8 actually have it listed as a common problem in Consumer Guide. Mine went bas at 38,000 miles, I complained to GM, and they split the cost with me even though the warranty was expired. They only do that it's a common problem. In fact, if you look here http://www.partsamerica.com/ProductD...pe=102&ptset=A you'll ntoice it says 2nd design meaning the inital design was flawed and they had to revise it. The revised design should not leak.1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
funny Ive never heard of the problem on our engines, just transverse mounted engines....Grand prix, buick, and such, big problem with those cars....never heard of it on our engines though.
05' CTS-V
00' Camaro - SOLD :(
I never saw "2nd design". That looks like the set I bought from Oreillys for $39.99
I broke one of the intake bolts off inside my intake from overtightening. I need a new Torque Wrench.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
The most common problem with the 3.8 series II's are the plastic upper intake manifold warping due to the heat of the EGR passages. It eventually warps enough that some of the coolant lines between the throttle body and the upper intake start leaking coolant into the intake itself.
Our cars do NOT have this style of upper intake manifold, thankfully. The FWD 3.8 series II's do have it [trust me, I've had to fix one before...].\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
I AM COMPLAINING NOW @ 33k miles.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
