How is the brake pedal supposed to feel? My car stops very smoothly and straight now, however it seems like even when the pedal is pressed all the way down my car just sort of quickly slows down, rather than abruptly stopping like I'd expect. Do all the Firebirds behave like this or is it possible something is wrong?
Just installed new rotors and pads, pedal feel
1996 Pontiac Firebird: A4, Flowmaster 80 Series, dual 3\" Stainless Steel tips, SLP CAI, Alpine CDA-9813 deck, Infinity speakers, Alpine Type R sub, MTX Thunder 801d amp, Tsunami 2 Farad Capacitor.<br /> <a href=\"http://www.cardomain.com/id/firebirdfury\" target=\"_blank\">http://www.cardomain.com/id/firebirdfury</a>Tags: None
did you bleed all 4 breaks?96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
did you make 100% sure you put more break fluid in after the install?95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
out in new fluid and bleed untill you see clean fliud, dont get any in your mouth [img]graemlins/barf.gif[/img]www.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by viper04af:
out in new fluid and bleed untill you see clean fliud, dont get any in your mouth [img]graemlins/barf.gif[/img]96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
Originally posted by Tyler:
</font><blockquote>quote:</font><hr />Originally posted by viper04af:
its also hot if you get it on your skin, it like burns... [img]graemlins/stickpoke.gif[/img]www.turbov6camaro.com
Definitely bleed the system after installing new brake parts. Start with the caliper farthest from the master cylinder and work your way forward. You will tell a significant difference.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Ok guys, thanks for the advice. I'll definitely try that. Is there any place I can get a quick walkthrough on how to do that? I trusted my Haynes Repair Manual to do the brake job and all the diagrams, pictures, and directions were completely wrong and didn't match my car. Prior to doing anything I checked my fluid level...it's full to the top and it seems pretty clear.1996 Pontiac Firebird: A4, Flowmaster 80 Series, dual 3\" Stainless Steel tips, SLP CAI, Alpine CDA-9813 deck, Infinity speakers, Alpine Type R sub, MTX Thunder 801d amp, Tsunami 2 Farad Capacitor.<br /> <a href=\"http://www.cardomain.com/id/firebirdfury\" target=\"_blank\">http://www.cardomain.com/id/firebirdfury</a>
you want to bleed the line from the pass-rear tire then the drv-rear then the pass-front then the drv-front. Bleed each line from far away to close until all the air from each line is out. Have a friend pump the brake to drain the fluid.
For future brake changes just use a C-clamp to push the piston back into the caliper. You won't have to bleed the lines.White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
check out these sites:
http://experts.about.com/q/2560/3332105.htm
http://www.installuniversity.com/White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
For future brake changes just use a C-clamp to push the piston back into the caliper. You won't have to bleed the lines.1996 Pontiac Firebird: A4, Flowmaster 80 Series, dual 3\" Stainless Steel tips, SLP CAI, Alpine CDA-9813 deck, Infinity speakers, Alpine Type R sub, MTX Thunder 801d amp, Tsunami 2 Farad Capacitor.<br /> <a href=\"http://www.cardomain.com/id/firebirdfury\" target=\"_blank\">http://www.cardomain.com/id/firebirdfury</a>
Originally posted by RallyRed 98:
from the reservoir, you have to take out just enough fluid so pushing the pistons back in doesn't overflow... then add that much more back into the reservoir.1996 Pontiac Firebird: A4, Flowmaster 80 Series, dual 3\" Stainless Steel tips, SLP CAI, Alpine CDA-9813 deck, Infinity speakers, Alpine Type R sub, MTX Thunder 801d amp, Tsunami 2 Farad Capacitor.<br /> <a href=\"http://www.cardomain.com/id/firebirdfury\" target=\"_blank\">http://www.cardomain.com/id/firebirdfury</a>
