My 94 firebird has a hesitation from when you are stopped and then lightly press the throttle to move up. It feels like it is going to die on me, but it doesn't. It only happens under light throttle. Other then that it's a strong motor. Is that just a thing a 3.4 does or is it bad? It has 133K on the motor.
3.4 has a hesitation
Could also be the throttle position sensor on the side of the throttle body. You can test that with a multi-meter by testing for continuance throughout the throttle range.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Originally posted by LwnGy83:
Could be a number of things... try looking at the basics... air filter, cleaning the intake and throttle body, spark plugs and wires... Maybe try some injector cleaner too. Good luck1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Mine has recently started doin that at 118k miles. All new plugs and wires as well. It only does it sometimes tho. Its recently got really cold as well. Im thinkin either dirty injector or just coldness.1994 Arctic White Camaro T-Tops(all options except leather)<br />80 Series Flowmaster Muffler<br />Ebay Cold Air Intake<br />Earthquake in the back known as a Kicker Solo Baric 15 L7<br /><br /> <a href=\"http://www.cardomain.com/id/sirshaun\" target=\"_blank\">http://www.cardomain.com/id/sirshaun</a>
I had a 3.4L w/ 130K miles on it and it started doing that as well... It turned out it was the catalytic converter. I let it go and it finally got so clogged that the exhaust started going through the EGR valve :( Have the cat checked out, if nothing else fixs the problem.\'97 Camaro 3.8L
Ya it started getting cold here too. Oh well it doesn't bother me that much, just get alittle bit more throttle. It always seems to help!2000 Firebird 3.8L, GU6, G80<br />Maple Red Metallic <br />And the rest is all stock.<br /><br />SOLD:94 Firebird 3.4L<br />Flowmaster 80 Series
would it help if he took off the catco and welded a piece of pipe in its place or does that hurt performance?<b><a href=\"http://www.cardomain.com/id/onebad9d5\" target=\"_blank\">1995 Red 3.4L Camaro</a><br /></b><br />Dont laugh if you see me pushing, no reverse, tranny needs rebuild.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
