Do a search, there have been a couple threads recently referring to the Daytime Running Lights (DRLs) Should get the answer your looking for in those threads.
Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
Are you talking about the automatic lights? They come on when its dark and you put the handbrake down? My car does the same thing, if I want to control the lights, I leave the handbrake on 1 click, and then turn on the lights
Originally posted by Fbody3400: Do a search, there have been a couple threads recently referring to the Daytime Running Lights (DRLs) Should get the answer your looking for in those threads.
im not talking about DRL's
Originally posted by Grimey: Are you talking about the automatic lights? They come on when its dark and you put the handbrake down? My car does the same thing, if I want to control the lights, I leave the handbrake on 1 click, and then turn on the lights
I really dont want to be driving around with my handbrake on.. i mean, it is a good idea, and i have thought about it myself, but i dont feel conftorable driving with the brake on... and yes, i know it isnt even working when it is on 1 click.
i am pretty sure that the DRL actually controls the headlights, so if u bypass the DRL's you can use the switch to on/off the headlights without having the ebrake notched up.
and to do that, bypass the drl's you put a resistor inline of the light sensor on your dash.
There are alot of write ups, ive seen this topic alot.
Originally posted by StrtRacer98: i am pretty sure that the DRL actually controls the headlights, so if u bypass the DRL's you can use the switch to on/off the headlights without having the ebrake notched up.
If you take the console off, you can get a look at the mechanism. It's very simple, basically when the parking brake goes down it pushes two contacts together. I think if you just pull the wire off of the contacts it would do the trick.
Originally posted by Little G: If you take the console off, you can get a look at the mechanism. It's very simple, basically when the parking brake goes down it pushes two contacts together. I think if you just pull the wire off of the contacts it would do the trick.
g
im thinking.. maby it is a bad idea to do this, because i will end up leaving my lights on, or not turning them on.
It is the same mod as turning off the DRLs. Behind your radio is a cigarette pack sized module that the windshield sensor ties into. Heres the fix w/ pics: http://www.xse.com/leres/ss/drl.html
\'01 Camaro Vert ~ Black on Teal (but Mean Green in the sun)
Originally posted by rhodeymark: It is the same mod as turning off the DRLs. Behind your radio is a cigarette pack sized module that the windshield sensor ties into. Heres the fix w/ pics: http://www.xse.com/leres/ss/drl.html
thanks for the link.
my main goal was to acually just be able to turn the handle to "off" and have the lights acually turn off. I guess it would be easier to shine a flashlight on the sensor [img]graemlins/rofl.gif[/img]
But yeah those drls are a pain in the ***,.. i am pretty sure there is another way to do it than that write up, seems a bit more complicated then what ive done.
Originally posted by StrtRacer98: Is this so you can run from a crime scene with the lights off and nobody will see you ? hahaha
no, when i go to pick my mom up from work, or park, my headlights shine in people's houses, and probably annoy the hell out of them, and i dont want to shut my car off, and start it back up again (although this is what i do now)
