on going problem under hard acceleration - FirebirdV6.com/CamaroV6.com Message Board
  • on going problem under hard acceleration
    been haveing trouble with my 95 3.4 a4 at first it seemd like a miss under acceleration so i did some things that needed to be done any way like injectors ignition module also i tested the coil packs they are good also new wires but still lose power on hard accel like half throttle or so any thing higher and no power can any one help also the ses light is not on and it works
    1995, 3.4l, v6 automatic, no pcm mods, no cat turbo thrush muffler, dry 100 shot of nos(ended the life of the car befor its time), cai, T.B. heater bypass,
    the car goes really rich under heavy throttle, unless its got a different tune
      this is not normal thow the car falls on it face bad
        Get your cat converter checked out, and maybe check for missfires with a tech2 @ gm dealer
        255/50R16 Tires, Pioneer Deck, Pioneer 4 Way speakers, PPI Amps, JL subs, Spec Stage 3 Clutch, Optima Yellow Top
          Check the ECM that the coils sit on - it functions as the distributor in our cars & they are prone to fail under load. The coils are strong but the module isn't.
          95Camaro3.4T5Conv Red/White*SLP Bilsteins*BMR Tower Brace*CAI*NiehoffIgn*NGK PlatPlugs*DelcoHiPerfWires*FlowmasterCatback*RedDe vilReso(no cat)* DynoMax Muffler*B & M Shifter*Eurolite Lamps*Yokohama Avid 235/55/16*GM 3.73s*Auburn LSD*Sirius*All DONE!
            If your tach jumps all over the place when it's missing, it's probably the ICM (under the coils). My last car did this, and it sounds similar to the problem you're having. Mine was also heat related, the problem really got bad when the engine was at operating temp.
              have no cat and got new plugs wires coils injectors and module also its a 95 so its obd 1 1/2
                need to put this thread back on top
                  obd 1 1/2? ;)
                  ECM = Electronic Control Module
                  ICM = Ignition Control Module
                  We already know its Electronic, duh.
                    Originally posted by slow6:
                    obd 1 1/2? ;)
                    its obd 1 with an obd 2 connector
                      Re: on going problem under hard acceleration
                      o2 sensor mabey?
                      scanner shows one is lazy
