broken fuel gauge = $500+ parts ? - FirebirdV6.com/CamaroV6.com Message Board
  • broken fuel gauge = $500+ parts ?
    the little gauge that tells me if the tank is full or empty (duh) is very sparatic, so i took the car to an automechanic to check it out. He says I need a
    "level sender fuel modular" & "level sensor dial"
    however he wanted $1400 for the parts and install. I laughed at him, and asked when can I come get my car, he says he wants $250 to give me my car back... shady b.s.
    So there is this other guy who says if i bring him the parts he will install it for $100. So I need to know where I can get these parts:
    "level sender fuel modular" (the pump is working i guess...but they are sold together)
    & a "level sensor dial".
    HOWEVER im not sure if i need one of the two, or both. would anyone know?
    [ December 06, 2004, 05:47 PM: Message edited by: 00firebird ]
    Its probly so expensive because he has to drop your gas tank. you can check www.gmpartsdirect.com for the cheapest parts.
      He lowered it to about 160, but i think now i have a problem with my abs light... http://www.camarov6.com/ubb/ultimate...c;f=5;t=007617
        my gas gauge is screwed up also but i just fill it up like everyother day so i dont need 2 get it fixed easier i think but i kno when it needs gas if i forget cuz it'll go down past 1/2 so it works but its off
          this guy is jerking you around, more than likely the sending unit in the tank is bad...and yes it does come as an assembly with the pump,..it will run you a few hundred for the assembly if you buy it and about $500 or more if you get it from the shop doing the repairs, labor is about 4 hours book time to remove and replace the pump. And $250 to tell you what the problem is...I could have done it in 10 minutes with a scanner and only charged you $80..not my fault there is a 1 hour minimum charge for labor
          2005 Magnum
            which parts does it sound like i need?
              you need a fuel pump, all of these parts come as one assembly called fuel pump. you can't get them separately. the cheapest auto parts fuel pump i've found is $385.
              1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
                hmm.. murrays auto parts told me $303.. Ill call them again
                  $385 was autozone online...go for the $303, that's a deal. shop got mine from a parts supplier for $345.
                    I've got an OEM one from an 01 Firebird, 14k miles, removed in perfect working order. Includes all eletrical hook-ups including fuel level sender and pick-up sock. Even a new gasket that goes around the top! (not pictured)
                    I uploaded a pic for ya here.... http://www.thenebula.com/carpics/pics4/DSC00121.JPG
                    $200 including fast shipping! Let me know
                      well I just got word that the only part I need is the level sensor, and i guess my pump is fine.
                      I picked one up at the pontiac dealership, it was $107. well lets hope it works!
                        Will this work for a 96' camaro?
                        My old car.<br />2000 Firedird 5-Speed<br />1/4 E.T. 15.601 @ 88.659 w/2.411 60\'<br /><br />New car.<br />1999 T/A 6-Speed<br />1/4 E.T. 13.181 @ 106.971 w/2.15 60\'
                          wow old... lol
                          assuming you used search to find this, you should have found another thread too (im not about to go find it [img]smile.gif[/img] ), for the older ones i think you had to buy the whole assembly. meaning no
