Traction Control??? - FirebirdV6.com/CamaroV6.com Message Board
Traction Control???
  • #16
    on a dry clean street, wheels straight, my car wont even come close to spinning tires.
    • #17
      they made a change sometime cause my friend had traction control on his 2000 and my 97 only has a light that tell you when you lose traction...
      • #18
        that there light, is'nt that ABS?
        bobby, do you have an open differential? Im guessing no, because you said "tireS".
        • #19
          not sure... from what I understand is traction control on v6s is wierd its a 3 channel TCS instead of a 4 channel like v8s...
          The "low trac" light is with the abs... just telling you the wheel sensors are registering different speeds. Like if the rear or any other wheels were spinning.
          IMO if you just bought the car, I'd do this regardless...
          -seafoam
          -fuel filter
          -plugs
          -wires w/ heat sheething
          -flush the motor on oil change
          • #20
            too bad it doesnt tell you which wheels are spinning
