What's your oil pressure? (3.8) - FirebirdV6.com/CamaroV6.com Message Board
  • What's your oil pressure? (3.8)
    Mine seems kinda low so I wanted to see what everyone else is getting.
    Idle:30-40psi
    Any throttle, rises quickly to 60-70psi.
    Between 60-70 psi regardless of rpm.
    2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
      mine would stay between 30 and 40 at idle and about 50 - 60 under acceration until i installed an oil cooler and now it stays between 60 and 70 all the time
      98 camaro 3.8 (THE PUNISHER)<p>JET STAGE II/B&M SHIFT PLUS/TAYLOR WIRES/SLP LOUDMOUTH w-3\" s- pipe/SLP CAI/SS MESH GRILLE/160 STAT/DERALE OIL COOLER<br />FLEXALITE TRANS COOLER/ 3.42-ZEXEL-TORSEN/KONIG MONSOON & KUHMO TIRES/MANUAL FAN SWITCH/1le sway bars & poly/KYB AGX SHOCKS/H&R SPRINGS/LS1 ALUMINUM DRIVE SHAFT/rk sport headers<p>WAITING FOR INSTALL:ssm heads,cam,3 angle valves/trans go shift kit
        When cold, like 60 something all the time. After some good driving, then it will drop down to 30-40. I wouldn't worry about it though, the 5.7 have 37 regardless of RPMs. They were nice to give this 6 some good pressure because I think that the knew that kids like us would be winding the **** out of them to find some power.
        1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
          2000, 3.8L with Mobil 1 10W 30 Synthetic:
          approx. 60 lbs. at all times.
          dave
            60 at idle and 70 +/- 5 while driving
            JR
            1996 Camaro 3.8<br />Edelbrock Exhaust, SLP Intake, Bosch, Platinum +4 Plugs, Accel Wires, SLP fan switch<p>\"Let the good times roll\"
              I use 10W30 Castrol tri-synthetic. My pressure stays slightly past 60 all the time.
              Kyle M<br />--------------<br /><a href=\"http://grdws6.netfirms.com\" target=\"_blank\">2002 Trans Am WS6</a> (silver, A4) - lid, cutout, stage 3 shift kit, 12 bolt, vig 3200, tranny cooler, bmr sfc/stb, torq thrust ii. <b>12.688 @ 106.47mph -=- 1.756 60\'</b>
                25-30 at idle when warm, give it a little bit of gas, and goes straight up past 60 psi
                Jared W. Drummond<br />jdrummon@vt.edu<br />1997 3.8 Firebird M5<br />-----------------------------------<br />*Flowmaster 80 Series Muffler* *SLP Cold Air Intake* *Zexel-Torsen LSD* *1-Piece DS* *Eibach Pro-Kit* *Removed MAF Screen* *Manual Fan Switch* *Mobil 1 Oils*<br />-----------------------------------<br />*Pioneer Premier DEH-920R Headunit* *Orion Cobalt 6 1/2\'s* *Sub Stealth Box w/ Alpine SWR-1021D* *Kenwood 728S Amp for Sub*
                  Good to hear I'm not the only one with 30psi during idle. I though I had a problem. I'm using the regular Mobil 1 5W30 now. I did notice an increase in oil pressure when I switched from Castrol Synthetic to Mobil 1 Synthetic. Now I just use the regular dyno Mobil 1 since I change the oil so often and it was getting expensive.
                    Same as the 2000 and higher guys, ~ 60 psi at all times, +/- 5 psi depending on throttle.
                    Scott
