I've had this problem for a while but it never seems to have gotten any worse or affected drivability at all. So here's what happens, whenever I slow down a lot to make a sharp turn (90* turn) I hear a faint kind of repetitive thumping from the rear end. It seems to have always been there since I had all my aftermarket suspension stuff installed. Could there be something lose and rattling around or what? I'm not to familiar with suspension maintanence so I'm not sure what to look for.
Funny sound from rear in turns...
LSD, this is a known issue with the Zexel Torsen units in the later models.
Torque sensing differentials make annoying nuisance noises.
Is something wrong with my LSD for it to make that noise or should I not worry about it. My car only has about 6 months left of warranty, so I'd rather get it fixed now if it needs repair.2002 Black Firebird:<br />A4, Y87, W68, T-tops<br />Best NA ET: 15.16 @ 90<br /> <a href=\"http://members.cardomain.com/darksde02\" target=\"_blank\">http://members.cardomain.com/darksde02</a>
If you have a warranty by all means get it checked out to be sure nothing is wrong. If you get a new rear end that would be awesome.
When mine started clunking I took it to a transmission place (my warranty was over with) to get the rear end fluid changed and the differential inspected. They said it was fine, just that it would be annoying.1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
Same here, it's been to the dealer twice and Fbody Central in MD once. It just seems to be a peculiar characteristic of this unit. It's annoying as **** but doesn't appear to be getting worse or causing any other problems.
^^ http://www.fbodycentral.com/phpws/ <they're in baltimore actually.
Have you gotten under the car yet and checked out the suspension and stuff? Check your bushings and suspension parts to see if everything is tight and secure. If not, take it to the dealer by all means while you still have a warranty left. Heck, I'd do that anyways just to make sure you milk all you can out of the warranty.AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
Originally posted by TheStupidFock:
Denis, where is Fbody Central? anywhere near Baltimore?
Sorry for the off-topic response guys! [img]graemlins/twak.gif[/img]
