Umm, yeah, my car has been smelling like gas for a few weeks now. When I mean "Smelling like gas", I mean that the gas can be smelled from within the car. It doesn't always happen though. It only tends to happen after I have driven her back and forth all day. Leaky gas line? Any suggestins would be appreaciated.
Car smells like gas from inside....
Check your lines going into your fuel rail. The o-rings inside wear out after a while and start to leak. Easiest way is to see if the bottom of the dust covers are wet. Also see if any has leaked to the indentions of the lower intake by the injectors.95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
Evap. emmisions canister maybe? [assuming our cars have one]. Fuel tank leak? I don't have this problem on my F-body, though.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
If the car smells after driving and disipates or smells after fill up, I would check the canister.Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
Originally posted by shock_core:
make sure the gas cap is all the way on??1996 Metalic Bule Camaro: no cat BORLA muffler 245-50-16 falken 502\'s descreened MAF 1pc driveshaft<br /><br /><br />soon to come: fixing that dagum Quarter Panel that i jacked up.<br /><br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a> <----CO-FOUNDER<br /><br /><a href=\"http://www.dahleinsurance.com\" target=\"_blank\">NEED INSURANCE?</a>
