how do i disconnect my automatice headlights when it gets dark - FirebirdV6.com/CamaroV6.com Message Board
  • how do i disconnect my automatice headlights when it gets dark
    When it gets a little bit darker outside my lights pop up, how do i disable this??
    99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
    No way! I thought all Firebird headlights were manually activated...
    I solemnly swear I am up to no good.
      Yeah, aren't Firebird's manual??
      But, if you pull up your parking brake one notch, just so the computer thinks it's on (do this BEFORE starting the car), it'll disable the automatic lights.
      I also believe there's a group of wires behind your head unit, if you pull it out, there will be a small gray box, and if you cut the blue wire going into it, it'll disable them. I'm not 100% sure on this though, and if it is true, it should also disable your DRL's as well.
      Kyle M<br />--------------<br /><a href=\"http://grdws6.netfirms.com\" target=\"_blank\">2002 Trans Am WS6</a> (silver, A4) - lid, cutout, stage 3 shift kit, 12 bolt, vig 3200, tranny cooler, bmr sfc/stb, torq thrust ii. <b>12.688 @ 106.47mph -=- 1.756 60\'</b>
        i'll look through my factory manuals. i think there is a way to do it but it might set a network code in pcm... let me take a look and post what i find...
        ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
          dont your guys' firebird do that, when the sun goes down and its a little darker out my headlights pop up automatically. and the only time my fog lights are on is when my headlights are on. :cool:
            Wow, didn't know such feature existed on 'birds. If anyone figures out how to do this, let me know, it would be kinda nice.
            <a href=\"http://www.cardomain.com/id/byoonull\" target=\"_blank\">My Old Car - 2000 Silver V6 Bird</a><br /><br />The replacement-<br />94 Firebird Formula - 383, TH400, and a big blower<br /> <a href=\"http://community.webshots.com/user/fastblackcar94\" target=\"_blank\">http://community.webshots.com/user/fastblackcar94</a>
              Must be something they only did to Canadian cars. I know one way to do it is to disconnect the light sensor on top of the dash next to the little blinking red LED. You have to pull the upper dash up then you will see the little light sensor. Just unplug it then put a jumper wire between the two terminals.
              EDIT: Also do NOT pull your parking break up one notch and drive around like that. It supposedly disables your ABS.
              [ May 12, 2002: Message edited by: SunsetOrange98Camaro ]</p>
              <b>1998 Cayenne Red Camaro 3.8 A4</b><br />-Whisper Lid, K&N, manual fan switch, DEI 508D<br /><br /><b>FOR SALE:</b><br />-Whisper Lid<br />-PAC OEM-1 adapter<br />-GM Delco 12 disc CD Changer<br />-MTX 4250D amp<br />-Kicker Free Air subs<br />-DEI 508D Proximity Sensor
                This page should be all you need.
                http://www.xse.com/leres/ss/drl.html
                  good info.
