This is not the right car for this forum but my friend has a 2001 saturn SL and the it is burning oil does anyone know how to fix this?
My Friend
There's no way we can tell you how to fix it. There's dozens of ways for an engine to burn oil, and there's no single fix. Take it to a shop to find the problem and go from there.Matt
1998 Mystic Teal Camaro M5
saturns do have a tendancy to burn oil when nothing is even wrong with them. Is it a lot though or just a little bit over time? I have a 92 saturn and it slowly drinks the oil.
The first two things I'd fool with [generically] are going at least one grade thicker on oil and replacing pcv valve and associated hardware.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
