Thermostat seems to be working fine. Not quite sure why it wouldn't blow warm. Any suggestions?
Heater doesn't blow heat
I had a car once where the heater core got clogged up. Maybe try to flush the system?SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
the blend dore is controled by cable not vacuum. Get your head down under the dash and turn it from hot to cold a few times and see if you hear the door move. it;s probably your heater core. feel bith heater hoses, if one is hot and the other is cool then there you go1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
I am....I've heard that little door open and close on numerous occasions when I was checking out an AC problem I was having. Pretty sure its a cable. The vacuum systems you refer to are mainly on upscale vehicles (Caddy, Lincoln, Lexus,etc ) where true adjustable thermostat and digital controls are in place. Our cars are really grassroots in that department. I'd believe that it was a coolant flow problem or even an air bubble in the system somewhere.
Blessings! [img]graemlins/wavey.gif[/img]\"this isn\'t flying...its falling...with style!\"<br /> -Buzz Lightyear<br /><br /><br /> 96 bright red firebird, T-tops, monsoon CD Flowmaster catback dual exhaust <br /><br /> <a href=\"http://members.cardomain.com/joyfellowship1\" target=\"_blank\">http://members.cardomain.com/joyfellowship1</a> <br /> <a href=\"http://www.joyfellowshipchurch.com\" target=\"_blank\">www.joyfellowshipchurch.com</a>
Originally posted by GrigoryRasputin:
</font><blockquote>quote:</font><hr />Originally posted by HBHRacing:
the blend dore is controled by cable not vacuum.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
yes, but the mode door is different from the blend door. they are seperate components. That will not effect the ability to switch between heat and cold1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
they do that so that you can have an infinet adjustment with the cable. you can't do that with vacuum. it's all or nothing, unless they designed a regulator in the heater control unit for adjusting vacuum which would just be a pain in the but.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...4 days ago
