Recently I've noticed that my idle is a little rough. I put some fuel injector cleaner in a couple of weeks ago and my air filter is pretty clean, but the roughness is still there. I've got an exhaust system from a z28 w/a cutout plate, but the plate is currently on.. No SES lights or anything.. Any suggestions??
Slightly rough idle..
Mine idled rough for about a two months, then one day I got in and started it, and it ran like crap, and threw a code, it was a bad plug, but it didnt throw a code until it got so bad it was causing a cylinder misfire.1997 30th Anniversary A4 w/ some mods
Might want to replace fuel filter. Check plugs most def also. [img]smile.gif[/img]RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
mine idles around 900 and is a tick rough.. proably much like yours.. I haven't really worried about it because everything else seems fine..
I "think" it may have started when I had a coil go bad though I'm not entirely sure.. anyway if it makes you feel any better yours isn't the only one.. [img]smile.gif[/img]-Brad
2000 V-Star Custom 1100
:rock:
