squeaking sound coming from hatch/rear area - FirebirdV6.com/CamaroV6.com Message Board
  • squeaking sound coming from hatch/rear area
    Anyone else have this? It is a distinct squeak. Not very loud, but definately noticeable. It happens when I go over a small bump or something like that but I know for a fact it is not my shocks/struts.
    1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
    What about your bushings or your spare?
    2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
      Check the spare and the jack. You'll get an annoying high pitched squeak if those are loose or rubbing.
      I solemnly swear I am up to no good.
        Check spare, jack, little rubber screw type things on the hatch, and maybe wrap the actual hitch on the hatch in electrical tape, I have had all sqeuk on me.
          Check the back seat, mine squeaked so I pulled them down bunched up a towel and squashed it in between the seat backs and the car. It gave enough pressure to stop the latch on the seat from squeaking.
            I had the same darn thing and it was the spare tire being shifted out of a vertical position to a leaning on the side of the car position. The rubber of the tire was squeeking going over bumps. Just reposition it and tiughten it up!
            1994, 3.4, 3.23, Dark Green<br />74,000 Miles as of 05/15/02<br />Have had tons of problems but still<br />love the darn thing,,,,
              Crickets?
                if i put WD-40 on my trunk struts and on the trunk latch it would clear my problems up
                  I had to do a tire change one time a looong time ago and didn't put my jack and spare back in properly after the fix. GOD, what a squeak that came from the tail end of my car when ever I went over bumps. Make sure that everything's back where it's supposed to be and down tight in the spare area...including the moldings that cover them.
                  1995 3.4 Camaro coupe. Not new or improved. Yet...<br />Hey, I changed a brake lightbulb! Is that too ricey? :^P
                    i think jiffy is right. i had the same thing, i'll bet its the rear seat latches. i took some electrical tape and wrapped the metal bars that it latches on to. took care of the problem
                      you have two rubber adjustable legs 9ont he hatch adjust them out by turning them to make it close tighter fixed mine
                      My new ride 2000 camaro, No mods yet still waiting for warranty to run out then all out heads, cam, and supercharger
                      • Andy H
                        Transmission removal help!!
                        by Andy H
                      • 2.8 Bird
                        Abs inop
                        by 2.8 Bird
                      • fishin
                        by fishin
