I have a 96 a4 and i do still have the 3.08 gears so i hope when i go to 3.42 and get tuning this will be better. If i am doing 40 and punch it the car pulls good in high rpms. Anything higher than that when i nail it all mit does is shift to 5,000rpm then as soon as it does it shifts to about 3,000 and pulls real slow. I cant get any power on top end cuz if im going over 45 and nail it it will onyl downshift once and i will be pulling from 3500 or so. Does anyone else have this problem? Is it cuz of the 3.08 gears? will 3.42's and tuning fix it? thanks.
Downshifting!?
Downshifting!?
1996 Camaro -- SLP CAI, Motorvator TB spacer, MSD 8.5 mm wires, 180 thermostat, Pacesetter headers, Catco 3 in cat, TSP Rumbler, custom painted interior, 18x9.5 Z06 replica wheels, Nexen N3000 265/35r18 tires, - Best 1/4 mile 15.3@89mphTags: None
what i would guess the "problem" is is that when you are going 40mph and punch it, the car is able to downshift into a lower gear because the RPMs arent as high, leaving you room to accelerate in that lower gear before needing to shift. When you go faster, the tranny is past the point of being able to shift into that lower gear because the rev is too high and you would hypothetically be at redline if able to downshift, which is unsafe and could cause major problems, so it downshifts into the next gear up, which is why you're left at 3500 rpms. I'm not quite sure if the 3.42's will fix that problem, although when the tranny downshifts, it may be at higher RPMS, because the lower gear ratio will make you run at higher RPM's than you do now. And you obviously will accelerate much quicker with the new gears. I'm hoping i'm right on that one, not an expert of automatic transmissions, but from what i understand, that is what is happening.
I believe the general consensus is that there is a dead spot on our cars from about 45-60 mph. Gears and custom tuning helps this out a lot.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
Gears technically help, but all they really do is move your "dead spot" to a lower speed.
My dead spot its to be about 35-50mph with my 3.23 gears. That is right when my car shifted into 2nd, at 35mph. Now with 3.73s it shifts at about 30mph and my "dead spot" is from about 30-40.<b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
My dead spot its to be about 35-50mph with my 3.23 gears. That is right when my car shifted into 2nd, at 35mph. Now with 3.73s it shifts at about 30mph and my "dead spot" is from about 30-40.1996 Metalic Bule Camaro: no cat BORLA muffler 245-50-16 falken 502\'s descreened MAF 1pc driveshaft<br /><br /><br />soon to come: fixing that dagum Quarter Panel that i jacked up.<br /><br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a> <----CO-FOUNDER<br /><br /><a href=\"http://www.dahleinsurance.com\" target=\"_blank\">NEED INSURANCE?</a>
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
