I have a 96 a4 3.8. I am going to upgrade my 3.08 to 3.42 and lsd. I know i will have to get a 97 pcm for my car. My question is will i have to get the vin number out of a different car for it to work or something? Just wanting to get everything together before i do all this.
TSP tuning and gears...
1996 Camaro -- SLP CAI, Motorvator TB spacer, MSD 8.5 mm wires, 180 thermostat, Pacesetter headers, Catco 3 in cat, TSP Rumbler, custom painted interior, 18x9.5 Z06 replica wheels, Nexen N3000 265/35r18 tires, - Best 1/4 mile 15.3@89mphTags: None
Why would i need to flash a 97 a4 pcm with a 97 a4 vin? Wouldnt it already have a vin for it. If i flash it would i have to find a vin for one with 3.42's already?1996 Camaro -- SLP CAI, Motorvator TB spacer, MSD 8.5 mm wires, 180 thermostat, Pacesetter headers, Catco 3 in cat, TSP Rumbler, custom painted interior, 18x9.5 Z06 replica wheels, Nexen N3000 265/35r18 tires, - Best 1/4 mile 15.3@89mph
They'll just need to know what gears that VIN# came with stock. You could easily get a VIN from someone on this board, as long as they know what their original gear ratio was [img]smile.gif[/img]<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Ok i sm going to call this junkyard tomorrow that is nothing but f-bodies. Just to make sure i have this right... i need to ask for a 93-97 z28 rear end with 3.42 gears and a 97 pcm? Does the pcm have to be for an auto? also are those the year rear ends that will work with my 96? thanks.1996 Camaro -- SLP CAI, Motorvator TB spacer, MSD 8.5 mm wires, 180 thermostat, Pacesetter headers, Catco 3 in cat, TSP Rumbler, custom painted interior, 18x9.5 Z06 replica wheels, Nexen N3000 265/35r18 tires, - Best 1/4 mile 15.3@89mph
It'll make it possible to just tune and bolt-in the PCM if it had the same tranny that you do. If it doesn't, then TSP can have it re-flashed with some VIN# and then tune it [img]smile.gif[/img]<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Now I just need a 97A4 PCM and a 3.42 LSD rearend. The shift points would be right wouldn't they? That is my main concern.2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
I had to reflash my PCM to a Y87 vin number when I got a new rear end in mine.
