Is the only option we have the MSD-DIS4? I found a Mallory that has a built in window switch and rev limiter for like $205, What about the Accell 300+ will that work? The accel 375+ has alot of options i Like. Would it be easy to make it work? Please list all options for performance ignition. Thanks.
Also, does the MSD window switch work with the DIS4? Or do you have to get it calibrated to a 2 cylender? Does it plug right in and work if you have dis 4 or does it need to be modified?
