Oil Pressure - FirebirdV6.com/CamaroV6.com Message Board
Oil Pressure
  • Oil Pressure
    Well first of all I was really happy today because my car got out of the shop after 3 days there. I got my tranny and oil leaks fixed and power steering hoses replaced. They needed new tranny sealant, and oil and tranny gaskets changed. My car runs smoother now and it just got a new oil change at the same time, all of tihs for only $560.
    Well I noticed that when my car had this oil leak problem the oil pressure seemed a little low, well right now its the same. It has new oil and supposedly the leaks are fixed, i checked under the engine and there was no sign of any leaks, I thought maybe the oil pan sealant was somethign they missed but after flooring the car a couple of times there still was no sign of oil leaking, so my question is this, what is the normal oil pressure on firebirds??
    I run like on between the 1/3 mark and half mark(which is 60) of the gauge when idled, when I go the pressure jumps up to over 60, just above it, is this normal or do I have to take it back and see if they missed something??
    2005 Chevrolet Corvette C6 <br />M6, Magnaflow\'s 14336<br /><a href=\"http://community.webshots.com/user/v6purplebird\" target=\"_blank\">C6 Pics</a><br /><br />Old car:<br />1996 Firebird A4<br />SLP Cold Air Intake<br />Magnaflow Catback Exhaust<br />Magnaflow Catalytic Converter<br /><br />George Mason University<br />CEIE Major<br />Pi Kappa Alpha<br /><br /><a href=\"http://members.cardomain.com/nsolano\" target=\"_blank\">Firebird Pics </a>
    I have the 3.8 and that is the exact same pressure mine runs at once the engine has heated up.
      Sounds about right. Depending upon the weight of oil and additives, if any, you are running then after warm up and at about 2,000 rpm the pressure should be somewhere between 55 and 75.
      2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
        thanks, I guess this means he has fixed my car right. Today when I went to George Mason to pay my deposit I smelled some burning smell when I got out of my car, but I guess it might be some of the left over oil that he didnt' clean up, I guess I can't expect the mechanics to perfectly clean up my engine.
