I have a few wiper problems...
1) When I first bought the car 2 years ago, the passenger side arm had no pressure on the windshield, and would not take off any water. Got that fixed...ever since then, there is this small corner at the top that just misses on regular speed. On high speed, the wipers sweep farther and it catches that area. This is only on the passenger side wiper. I want it to cover the whole part now.
2) On high speed, I am having a bigger problem. During extended high speed wiper operation, the wipers will work, and then just start sweeping halfway, while smacking the cowl big time! High speed smacks the cowl during normal use, but when this problem happens, it smacks REALLY HARD! I drew a crappy picture to show some people the sweeping area covered during normal high speed and bad high speed... Wiper Woes. To correct this, I need to shut off my wipers (while driving in heavy rain), then restart them. The high speed action will work just fine...and then die again. I basically have to use normal speed in downpours :rolleyes:
You can see in the Normal pic where that corner is up top that the passenger side wiper misses in #1.
Thanks in advance! [img]smile.gif[/img]
EDIT: If pic doesn't show up, try to copy & paste
[ April 20, 2003: Message edited by: TheV6Bird ]</p>
