Headlight help!!! - FirebirdV6.com/CamaroV6.com Message Board
Headlight help!!!
  • Headlight help!!!
    Ok it's not about my Camaro. I have a '95 GMC jimmy that for some reason is being a b**ch lately. Ok i noticed that after the high beams have been on for a while they start to flash a bit or flicker off and on again. if i switch to low beams it doesn't do it. i changed bulbs today to see if one was shorting out but that didn't fix it at all. what do you guys think it is? Help would be appreciated.
    2000 Grand Prix GTP- Bronzemist Metallic: K&N Fenderwell Intake,3.4\" Thrasher Pulley, v1.0 DHP PCM, 3\" Mandrel Bent DP,Ubend Delete,Dynomax SuperTurbos, 180* Thermostat.<br />Soon to come: ZZP SSIntercooler or N20 or both:)
    fuse needs replaced?
    Soon to be Mommy!<br />2005 Honda Pilot EX-L
      make sure all the ground wires are nice and secure.
      2011 Camaro LS 6M, in black.
        not sure if the fuse is bad. it wasn't blown or anything. i'll try that tommorow
