I am buying tires for my 96 bird for the first time. The tires that are on the car are the same ones that were there when I bought it a year ago. It is a fine mix of sumitomo,yohahama, pirelli, and suho....one of each (eeeeeuwwwww!) Anyway, the tires they have on there are the 235-55-16s on the stock bird rim. I see by looking into it that the original stock tire is a 215-60-16. Is there much difference in the two tires appearance and performance wise...and which do you think I should go with [img]graemlins/burnout.gif[/img]
which TIre?
which TIre?
\"this isn\'t flying...its falling...with style!\"<br /> -Buzz Lightyear<br /><br /><br /> 96 bright red firebird, T-tops, monsoon CD Flowmaster catback dual exhaust <br /><br /> <a href=\"http://members.cardomain.com/joyfellowship1\" target=\"_blank\">http://members.cardomain.com/joyfellowship1</a> <br /> <a href=\"http://www.joyfellowshipchurch.com\" target=\"_blank\">www.joyfellowshipchurch.com</a>Tags: None
If you have the Y87 package, your car came stock with the fatter/lower profile 235/55/R16. It's a decent size for a sixteen inch rim and I'd suggest sticking with that size and ordering four new Kumhos off of Tirerack.
The main difference between the two is that the 235/55/R16 are fatter on the tread and narrower on the sidewall, giving better tracking and performance in general (and lower profile tires tend to look better on our cars).<a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
Definitely get the 235/55/16's. Much better than the 215's all around plus they look better.
I started out with 235/55/16's and then chose 255/50/16's when those wore out. The only downside for me to the 255's is they decreased my gas mileage a little.I solemnly swear I am up to no good.
I've seen the tirerack headers here on the site. I am really not equipped to do mounting or balancing myself...where do you guys have that done locally when you buy tires off the web?\"this isn\'t flying...its falling...with style!\"<br /> -Buzz Lightyear<br /><br /><br /> 96 bright red firebird, T-tops, monsoon CD Flowmaster catback dual exhaust <br /><br /> <a href=\"http://members.cardomain.com/joyfellowship1\" target=\"_blank\">http://members.cardomain.com/joyfellowship1</a> <br /> <a href=\"http://www.joyfellowshipchurch.com\" target=\"_blank\">www.joyfellowshipchurch.com</a>
i went with dunlop sp5000 245/whatever/16. order from tirerack (the ground shipping was practically overnight from new jersey).
drove them up to my local goodyear who mounted and balanced them (yes, 4 tires will fit in the firebird).
i went to 255/50ZR16 and the car handle much better and wet roads was no problem at allwww.turbov6camaro.com
1997 3800 Series II Camaro
When I got my new tires, I ordered from dicount tire direct I found they were cheaper and free shipping! Check them out.New Toy Red 94 Formula LT1
RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
I checked my car again, and the size that they have on the car are 245s. I looked at the Tirerack page on deciphering tire sizes and let me see if I get this straight....the 215,235,245...those are all various widths in Cm's right?\"this isn\'t flying...its falling...with style!\"<br /> -Buzz Lightyear<br /><br /><br /> 96 bright red firebird, T-tops, monsoon CD Flowmaster catback dual exhaust <br /><br /> <a href=\"http://members.cardomain.com/joyfellowship1\" target=\"_blank\">http://members.cardomain.com/joyfellowship1</a> <br /> <a href=\"http://www.joyfellowshipchurch.com\" target=\"_blank\">www.joyfellowshipchurch.com</a>
It's the width of the tire in mm, the next # after that is the aspect ratio, or how high the sidewall is in relation to the width of the tire in % (245/50-16 means the tire is 245 mm wide, the sidewall is 50% of 245mm, on a 16 inch wheel). Hope that clarifies.
Edit: Oops, forgot to add my recommendation:
http://www.discounttiredirect.com/di...odeIndex=38925Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
