s.e.s. light - FirebirdV6.com/CamaroV6.com Message Board
s.e.s. light
  • s.e.s. light
    my 95 3.4L camaro with a obdII comp. the s.e.s. light is driving me f#@%$n nuts.
    it comes on for a bit goes off for a week or
    2 then back & off & ON & off & on......
    ive had it checked nothing comes across the computer. has any one else had this prob ??
    one other thing,my camaro is base , but not rock botom base,i have fog lts,cruse & pwr trunk, i want to make my doors p/windows & p/locks.
    my fuse box has fuses in it. does anyone know if there is power running to it ?? or if it is really wired ??
    thanks for any help.
    -razzle-
    razzle
    The 3.4s all came with the OBDI not OBDII. That's odd to throw an OBDI, typically to do that there is something REALLY wrong. I would take it to a shop and have it checked out.
    <b> \'95 Camaro 3.4L A4 <i>Rikku</i><br />AutoX - Drift - Street </b><br />\"Sideways is faster.\"
      When is it coming on? What are the symptoms?
      ie. mine comes on when I am driving on the hwy and coast, I get a EGR error. When I turn the car off and restart it a few minutes later I have no SES light.
      Give us some more info.
      If you want a code scanner go to www.autocheckup.com sometime he has some good prices on reconditioned units.
      Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
        <blockquote>quote:</font><hr>Originally posted by CARdiac:
        <hr></blockquote>
        I have the exact same problem. Have you tried replacing the EGR? I was wondering how to get this fixed.
        <b>Cheers!</b><br />Scott<br />1994 Camaro 3.4L V6<br />Flows, Underdrive Pulley, and a 180 Thermo
          My EGR is fairly new, after I replaced it I was still getting the code. I had someone tell me it is actually that bent pipe from the EGR to the intake (it gets clogged with carbon, since I am "CARdiac" I tried angioplasty). I cleaned it once and I stopped getting the code for a while...a new pipe is $18, I need to pick a new one up...
          Since the pipe is relatively cheap compared to the $160 EGR, you may want to try replacing that first.
            first of all. thanks for all the input.
            now, my obd-II is stock from the factory,
            i went to the dealer and found that out, i also have a buddy that has a 95 z-28 with a obd-II
            stock. aparentley they started putting them in some in 95 then went full bore in 96. (my guess??)
            on my s.e.s. light i have no symptoms,runs fine,
            the light comes on for no apparent reason ? ive used several of the hand held diag. comp's i get no errors at all.
            razzle
              it gets clogged with carbon, since I am "CARdiac" I tried angioplasty.<hr></blockquote>
              [img]graemlins/rofl.gif[/img]
              I will look into that. Thanks [img]graemlins/thumbsup.gif[/img]
                <blockquote>quote:</font><hr>Originally posted by razzle:
                <hr></blockquote>
                If you have a 3.4L you have the OBDI computer. Now the 95's have the OBDII connector underneath the dash, but still have the OBDI computer running the car. Trust me, it's not a OBDII.
                ---<br />-\'95 3.4L M5 Camaro
                  All that I know is that my 95 has OBDII, but with the 3.8, the V8's got it too, but I haven't heard of the 3.4's getting OBDII.
                  1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
                  • Andy H
                    Transmission removal help!!
                    by Andy H
                  • 2.8 Bird
                    Abs inop
                    by 2.8 Bird
                  • fishin
                    by fishin
