Whistling Goodyear Gatorback? - FirebirdV6.com/CamaroV6.com Message Board
  • Whistling Goodyear Gatorback?
    Not too long ago i replaced the drivebelt on my Camaro with the Goodyear Gatorback i bought at an auto part store. After i installed the new belt i took notice to a whistling sound coming from the engine. The sound becomes louder as the engine revs higher.
    Is this normal for the Gatorback?
    I know i bought the right belt, i compared it to the old one and both were the same size.
    I also know i have have the belt on the right way.
    I don't know what it could be other than the way the grooves are designed on the belt.
    2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
    yes the gatorback has a whistle to it. it will go away after you put a little bit of wear on it. so yes, it is normal.
    Mods List:FREE ram air mod,FREE air lid smoothing mod,Air silencer removal,K&N Filter,Magna Flow Exhaust. cat delete, 3.42 + lsd.2600 stall tc,alto red eagle complete tranny rebuild.
      I replaced the old drivebelt with the Gatorback about 2 months ago and since then i have put at least a good 3,000 miles on my car.
      How long until the whistling stops?
      I'm not sure i understand why the whistling goes away after some wear is put on the belt. If it still does it after 3,000 miles won't it still make that noise another 3,000 miles from now?
        It takes 3,001 miles...
        You just cant cut things short these days...
        Damn kids...
        Red 98 A4 Firebird<br />..its pretty..<br />- - - - - - - - - <br />6 Infinity 3-way speakers with Alpine deck and 720 watt Kenwood amp..
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
