VSS Signal - FirebirdV6.com/CamaroV6.com Message Board
VSS Signal
  • VSS Signal
    Is the vehicle speed sensor signal a voltage, a pulse, a current, or something else?
    How does the pcm know how fast the car is going- what exactly does it read off the VSS?
    All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
    Its a magnetically created pulse. The old VSS was only good from 0-255mph (8bit) but I think the new ones are a lot more accurate and are 16bit.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      Re: VSS Signal
      ressurecting this post...
      i changed my Tranny from a 1994 t5 - 2000 t5. the problem is the VSS is different now. i got the right plug for it...plugged it in and the speedo is goin whacko - at 8mph the speedo says im doing 80. i topped the speed governor @ a whopping 15 mph!
      so any thoughts on how i could adapt this to work for my car? resistors - etc...
      any help would be greatly appreciated as i dont have the time/money to adapt the old VSS to the new sensor.
      thx.
      hybrid - \'\'hI-br&d - The offspring of a cross between species.
      Co-Founder West Coast F-Bodies
      West Coast F-Bodies Car Club - WCFB Message Board
        Re: VSS Signal
        Take that sensor out and put the old one in .
          Re: VSS Signal
          annnd if that isnt an option?
          i.e. - if the tranny currently in the car cant use the old sensor...
          what then.
            Re: VSS Signal
            go buy a sensor . you dont have to pull the trans to change the sensor
              Re: VSS Signal
              there completely diffrent pulse patterns . not interchangeable.
                Re: VSS Signal
                the problem is that the sensor in the 2000 trans is an effect sensor like the camshaft position - whereas the old vss in my 1994 trans is a gear driven sensor.
                i cant use the original sensor with the new trans due to the fact that it would have nothing to drive the sensor.
                any ideas?
