at 80mph my rpms are at like 2750 and i have 3.08 open end i dont think it should be that high at 80 or is that normal??? oh and its a 3.8L 5 speed 96
Rpms at 80mph
5spd, 3.23, 80mph ~ 2500RPM
Precisely its 81.4MPH = 2500RPM.2002 5-spd NBM Camaro
Details: www.1lev6.com
So the lower numerically your gear ratio is the higher your cruising RPMs will be? I put a 50 series tire on my bird and now my cruising RPMs are higher. Did I increase or decrease my gear ratio?1993 Pontiac Firebird 3.4L V6 A4<br />F41 RPO suspension option<br />119K miles<br />Fastchip<br />K&N \"Filtercharged\"<br />Airbox cuttout CAI<br />ASP underdrive pulleys<br />Pacesetter Headers<br />Flowmaster 80 Series 2.75 cat-back<br />MangaFlow Hi-Flow Cat<br />Corvette Servo<br />16.4 @ 81 MPH
<blockquote>quote:</font><hr>Originally posted by BradC:
So the lower numerically your gear ratio is the higher your cruising RPMs will be? I put a 50 series tire on my bird and now my cruising RPMs are higher. Did I increase or decrease my gear ratio?<hr></blockquote>
A lower gear (higher numerically) increases the engine rpm at whatever speed. If you have reduced tire height, then you effectively are running lower, shorter, or higher numerically gears... pick which ever term you like best.Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
<blockquote>quote:</font><hr>Originally posted by Dominic:
Precisely its 81.4MPH = 2500RPM.<hr></blockquote>
Sounds right to me. (Manual 5 Speed, with 3.23's)1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
bout 2700 at 80, but i gots the y87 :D1997 Firebird Convertable White, with custom Purple pin striping and custom Purple detailing!!!<br />Y87 Performance Package W68 Apperance Package<br />Boydes, aluminum rims 16\" BMR STB <br />SLP Cold Air Intake 3\"hiflow cat 3\" dynomax custom catback, 2.5\" Flowmaster 80. Slp Take off Shocks, Springs And Struts. Transgo shift kit with corvette servo!<br />Sony Explode CD Player Kicker Comp VR 12, and Explode 760Watt amp!!!<br />5% Tint on the side windows, Correction officially 2% on the side windows, or at least that is what the highpo said and 15% on my rear window<br />Yup Purdy Car!!
<blockquote>quote:</font><hr>Originally posted by Camarobabe:
80mpg - 2600rpms - 3.42<hr></blockquote>
80 mpg eh? thats pretty good [img]tongue.gif[/img]
Dru. have you checked your rpo codes? are you sure you dont have 3.42's?
Dru. have you checked your rpo codes or did you buy it used? maybe someone put them in?
80 mph 2300 rpm - 3.081999 Firebird Black<br />A4 3.08 gears<br />Mods: Carbon Fiber Whisper Lid, Raised Air Box, K&N Air Filter, Direct Hits Ignition, Flowmaster American Thunder 3\", 160 Degree Hypertech Thermostat, SLP Fan Switch, 3\" High Flow Cat<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=273903\" target=\"_blank\">My car on Cardomain</a>
<blockquote>quote:</font><hr>quote:
<hr></blockquote>
oops, [img]graemlins/dunce.gif[/img] I guess that would be pretty good!!2001 Camaro Y87 A4<br />Arctic White<br /><a href=\"http://camaroz28.cardomain.com/id/camarobabe\" target=\"_blank\">my car</a>
