Hey, i was having some problems with my SES light, so i took it to autozone and they told me the codes. I had a Random Missfire code, so i replaced the plugs and plug wires.. still had the code, and the car was running crappy at high RPM's. so i replaced the Coil packs (all three), the car runs great, it's smooth all the way to redline, but i've still got my SES light on. I disconnected the neg battery cable for about 30 minutes.. nothing. i turned the ignition on and hit the gas peddal three times... light's still on. I was told it may be a hard set code that i'd have to get GM to reset... is this true? please any info would be great. thanx..
Justin.
Justin96Bird / Justin98TransAm<p>1998 Navy Blue TransAm<p>Whisper Lid<br />free ram air<br />K&N Filter<br /><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">DynoMouth Exhaust</a><p><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">http://www.hhbc.com/justin96bird/index.htm</a>
You can also disconnect the battery for 15 min or more but you loose your radio stations which I dont think will happen if you pull the fuse.
Nevermind I didnt read your full post.
[ April 06, 2002: Message edited by: srogersilkl ]</p>
RED 1995 CAMARO 3.4L<br />Moroso cai, ASP Underdrive Pulleys, B&M Shifter, Flowmaster 80-Series Muffler, Polygraphite Sway Bar Bushings, Endlinks, and Panhard Rod Bushings
