Originally posted by Everglades W68: I'm just wondering what a GM dealer would charge for this repair if you pay for it yourself.
Bring lots of vasaline with you. Anything/everything cost's more at a dealer, especially with installation. You're better off buying a motor from autozone and getting a shop to install it. It will probably save you $150.00 or MORE by going that route.
Go to our Mod Ency and click on the stereo section. TONS of walkthroughs and FAQs in there....including a superb walkthrough for power window motor replacement.
Originally posted by 96firebird311: Go to our Mod Ency and click on the stereo section. TONS of walkthroughs and FAQs in there....including a superb walkthrough for power window motor replacement.
^what he said
I replaced both of my window motors using the guide in there took me about an hour and 1/2. Just follow it step by step and you can't screw up. The hardest part to do is drill out the rivits that are holding the stock motor in and its pretty much down hill from there.
my dealer charges close to 300$....it'll take a tech maybee 10-15 mins to pull the car in, get the motor from parts install it, and park the car again....takes me about 15 mins to do the job myself
